First post, by noshutdown
the board in question is the same model as this thread, just another one which is NOT corroded by the leaked battery:
please identify: unknown typical generic 386dx board
as you can see the board has amd386dx-40 cpu and opti 82c495 chipset. it comes with 4 ISSI IS61C256AH-20H sram and a winbond W2465AK-15 tag ram, so it should have 128k of cache right? in bios i set a conservative 3-2-2-2 cache timing and 1wait dram, which not the fastest setting but should be by default for 40mhz, but all benchmarks performed very slowly:
3dbench at 12.5fps(~15fps is up to standard)
norton sysinfo reported 31.2 units while the reference 386dx-33 is 36 units
both cachechk and cct386 reported 32kb of cache, cachechk's cache speed is ~47us/kb, and dram is ~115us/kb.
speedsys freezes at extended memory test, it reported a ~22.5mb memory bandwidth at topleft though.
in contrast, another board with micronics mx83c306 chipset, which has only 8kb of cache, scored 14.5fps in 3dbench and i heard other people's boards with amd386dx-40 scoring ~16fps, so this opti board is obviously performing badly.
could it be faked(remarked) cache chips, or that the bios is stupidly bugged that its not setting the chipset up correctly? there is a "cacheable range" option in bios, and it says should not exceed the actual onboard dram size, so i choose 16mb.
Reply 1 of 12, by konc
Bring the timing down as much as possible and try again, you'll be surprised by the difference it makes 😉 If your memory can sustain the lowest values with 0 WS you'll see a sysinfo result of at least 41-42. Regarding the cache, yes that's 128K. Have you checked for cache size configuration jumpers? I don't know if it has, just throwing in an idea.
Reply 2 of 12, by noshutdown
i swapped in two sets of 128kb -15ns cache(each set made up of 4*32kb and a 8kb tag ram of course), but the board only reported "cache ram bad, cache disabled". this is unlikely for both sets of cache to be bad, as they were removed from other boards.
so these are my guessing:
1. the original cache that came with this board are remarked, they are actually four 8kb chips rather than 32kb.
2. the bios is either bugged or hacked to display 128kb when 32kb is actually plugged, and would not work with real 128kb.
Reply 3 of 12, by noshutdown
i looked for cache size jumpers but there were none, there is a small chart printed on board telling you to plug four 8kb and a 8kb tag to form 32kb, and four 32kb and a 8kb tag to form 128kb, but never mentioned any jumpers.
Reply 5 of 12, by noshutdown
progress: i replaced the bios chip with the one from the corroded board(since they have same chipset and even identical layout), and it reported 32kb cache at post!
so my two guessings are right:
1. the original cache that came with this board are remarked from 8kb per chip to 32kb per chip.
2. the original bios was hacked to report 128kb cache when 32kb is actually plugged.
however the replaced bios still reports "cache ram bad, cache disabled" when i plugged 4*32kb cache chips, so i have to believe that they are indeed bad and use 32kb cache for a few days before my purchase arrives.
since 32kb can only cache for 8mb of ram, i set cacheable size to 8mb in bios and the tests all finish without crashing(they crashed a lot when i set cacheable size to 16mb before). the cachechk results are:
cache: 47us/kb(21.3mb/s)
cached ram: 115us/kb(8.7mb/s)
uncached ram(or cache disabled): 67us/kb(15mb/s)
also changing dram wait stats doesn't seem to affect cached ram speed. they affect uncached ram speed a bit but 1wait is the fastest, while 0wait and 2wait are both a bit slower at 74us/kb.
is this kind of performance normal? can anyone give your 386dx40 cachechk results for comparision?
Reply 6 of 12, by konc
sure, here are my results:
cache: 37.8mb/s
cached ram: 8.7mb/s
uncached ram(or cache disabled): 14.9mb/s
What are your lowest possible/reliable timing values and norton's sysinfo result with them?
Reply 7 of 12, by noshutdown
konc wrote:
sure, here are my results: cache: 37.8mb/s cached ram: 8.7mb/s uncached ram(or cache disabled): 14.9mb/s […]
cache: 37.8mb/s
cached ram: 8.7mb/s
well, looks my ram performance is inline with yours, except that my cache is running at slowest 3-2-2-2 timing as the sram chips are marked -20ns(they are faked anyway). i'll see if i can get away with 2-1-1-1 when my purchase of -15ns cache and -12ns tag arrives.
by the way, is there any 386 chipsets without cached dram penalty?
that is, in common sense, the chipset would only access dram after a cache miss, therefore the total time of a cache-miss read would be cachetime+dramtime.
however, a better designed chipset shall initiate a cache read and a dram read at a same time, and discard the dram access once cache hits, thereby eliminating cached dram penalty.
Reply 8 of 12, by noshutdown
bad news: the purchased sram chips arrived, but the damn board still reports "cache ram bad, cannot enable cache" at post. i can't believe that several sets of sram chips are all bad(even if just 1 out of 4 chips is bad), so i assume that something is wrong with this board that it wouldn't work with 128kb cache.
and there is no cache-related jumper on the board, i tried two unidentified jumpers but they don't do any good.
Reply 9 of 12, by quicknick
I have that board. Since i got it without cache, added some chips last year, and it wasn't without problems - got many "cache ram bad" messages, in the end cleaning (scraping) each IC's leg with a razor cleared the errors, but i didn't think to do some benchmarks before and after. I don't think i will remove the chips again (legs got flimsy after so much pushing and pulling), but in the next few days i can run some tests/benchmarks if you are interested.
Reply 10 of 12, by noshutdown
oh, did you add 32kb or 128kb of cache? the board never reported any problem when i plugged the original 32kb cache back, and the purchased caches' legs are in excellent condition, so i doubt if the problem is caused by legs contact.
Reply 11 of 12, by quicknick
I have installed 5 pieces of UM61256FK-15 (tag ram identical to the other 4 chips), so i guess that's 128KB cache. It will be a few days until i can run some tests on that board.
Reply 12 of 12, by quicknick
Here are my results (speedsys and cachechk with cache enabled and then disabled, landmark only with cache enabled).
Tightest cache timings, main memory 1WS.
https://imgur.com/a/IRovBjv
