First post, by Kreshna Aryaguna Nurzaman
Some people use CF to IDE adapter for their retro system, and I'm very interested to use it on mine too. Found this following hardware on the net: Startech 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader. What makes it interesting is that it's ejectable. Not only it makes it easier to switch between O/S (for example, a 2 GB CF card installed with DOS, and a 32 GB CF card installed with Windows 98, for the same Pentium III system), but it also makes it easier to backup the said CD card.
However, is it bootable? Cannot find any specs that say so. Anyone experienced with it?
Kreshna Aryaguna Nurzaman.
Reply 1 of 12, by MMaximus
I have several of these, but mine were made by Addonics (ADIDECF). However, they look so similar that it might actually be the same product.
Do not be fooled by the term "ejectable" - on mine the "eject" button is flaky and doesn't work: I need to pull out the card to remove it, however it's not a big deal and it works. The adapter is bootable provided the memory card is properly partitioned and compatible with the system.
You can see it installed on my socket 7 system here. I've also got one with a beige bay adapter lying around somewhere.
Hard Disk Sounds
Reply 2 of 12, by PCBONEZ
Why are there two ribbon cable connectors?
Reply 4 of 12, by Kreshna Aryaguna Nurzaman
I see, thanks for the information. I don't mind having to pull out the card, though. What's important is the ability to swap CF without opening the PC case.
Reply 5 of 12, by MMaximus
For this purpose you also have bracket adapters that sit in an expansion slot at the back of the computer. They're generally a bit less expensive and are more subtle when you'd rather keep the vintage look of your retro rig.
Hard Disk Sounds
Reply 6 of 12, by Kreshna Aryaguna Nurzaman
MMaximus wrote:
For this purpose you also have bracket adapters that sit in an expansion slot at the back of the computer. They're generally a b […]
Thanks. Floppy mount and black color is fine for me. All my retro systems would be move to rackmount case anyway, so I won't worry about retro look.
Reply 7 of 12, by .legaCy
I actually use one home made 5.25" drive bay mount, i just curved back the expasion slot bracket to make it flat(instead of a L shape), with a dremel i cut a slot on the bay cover and smoothed it with a nail file to make it look decent and drilled a hole on the bracket and then marked the bay cover to align the holes and used a m3 bolt and nuts to secure it in place and to make it look a little better i covered the bolt heads with two m3 bolt top cover, i even drilled small holes for the LED on the adapter. it is actually pretty decent looking on my 486 DX4, the ease of use provided by this solution is amazing.
Reply 8 of 12, by chinny22
I had a similar different cards for different OS's setup on a 486 while back.
If you use have a couple of the same CF cards you don't even need to worry about changing the HDD setup in BIOS as the PC wont know its 2 different cards.
Reply 9 of 12, by bjwil1991
I had the PCI bracket version a long time ago, and that was amazing, but, I have a huge collection of games for my Windows 98SE machine that cannot keep up with a 2GB CF Card (which is in my 486 Packard Bell due to HDD limitations) or 4GB CF Card. It is amazing to have something to look at photos that were stored on a CF card that older digital cameras used before SD/XD/MMC cards.
Reply 11 of 12, by Half-Saint
Hi! I'd really like to see a pic or two of your solution 😁
Reply 12 of 12, by infiniteclouds
Awesome! I wanted to use one of these because my expansion slots are backed to the brim but the STartech's black one would look awful in my beige case. Thanks for showing off the Addonics one.
