First post, by user33331
- Member
Hello
What is that 10mm width clear tape found inside laptops and such devices ? The tape is pretty adhesive and harder to remove than the normal office's 3M magic tape(TM) ? When you take it off it won't stick anymore so I have to buy some new tape now.
Is it that "Kapton/Polyamid tape" found in China stores ?
What tape brand do people use to replace these tapings inside laptops ? This is a newer Lenovo laptop so about every wire is taped to the casing inside. Screen's flex cable is also connected with tape.
Also if multiple what different tape types to buy for these kind of purposes ?
