How to install dos on 486dx2 with cd-rom or floppy drive ?
Postby Aglenoth » 2018-4-22 @ 12:57
Hello, i have recently found this 486 desktop Elonex WS-425SX but I can't install any software , I have tried to install dos on another computer, however when i put it back , and set disc donfiguration (it's Toshiba MK1724fcv hdd) , and when i try to boot it Outputs this :
Starting MS-DOS
Starting MS-DOS
__
And then it hangs, no beeps , nothing.
Any help is higly apriciated :)
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Aglenoth
Re: How to install dos on 486dx2 with cd-rom or floppy drive ?
Postby derSammler » 2018-4-22 @ 13:05
Quickly press F5 when the Starting... message appears. If that works, check config.sys for stuff that causes the freeze.
derSammler
Postby dionb » 2018-4-22 @ 14:16
DOS is pretty basic and boots off BIOS routines, so if your DOS install works on one PC compatible computer, it should do so on another.
If not, you've got hardware problems. Given that you get 'Starting MS-DOS' the HDD seems to be recognized and at least some data (the boot sector) is being read. Possibly your HDD is too large for the BIOS, but I'd be surprised if 362MB would be too large for anything.
Other suspects: that Elonex WS-425SX would have shipped with a 486SX-25, yet your photograph shows a 486DX2-66. Possibly some component (low-spec RAM or cache) doesn't like the 33MHz system speed that uses. Try underclocking to 50MHz (25MHz bus speed) and see what happens then...
User avatar
dionb
Postby dosgamer » 2018-4-22 @ 14:51
Easiest is to use a CompactFlash card and mount it as a disk in VirtualBox on any PC and install away. Second easiest is to use an IDE-USB adapter and do the same thing.
Coppermine Celeron 800 @ 1.12GHz (8x140) - Asus P2B Rev. 1.12 - 256MB PC133 CL2 - Voodoo5 5500 AGP - SB AWE64 CT4520 - Roland SCC-1 - Intel Pro/1000GT - 1.44MB Floppy - ATAPI ZIP 100 - 120GB IDE - DVD-ROM - DVD-R/RW/RAM - Win98SE
User avatar
dosgamer
Postby Aglenoth » 2018-4-22 @ 16:20
dionb wrote:DOS is pretty basic and boots off BIOS routines, so if your DOS install works on one PC compatible computer, it should do so on another.
I have talked to the guy who sold me this unit, It's WS-450 but with different front panel , soo i apologize, and the rest inside is from WS-450 as well , even the hdd was included there originally , I don't know where is the problem :/
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Aglenoth
Postby Aglenoth » 2018-4-22 @ 16:21
dosgamer wrote:Easiest is to use a CompactFlash card and mount it as a disk in VirtualBox on any PC and install away. Second easiest is to use an IDE-USB adapter and do the same thing.
I love to keep system original, I could get my hands on adapter, but since i have second system that i use for file transfer, there is no extra need of using one :) I guess it's hardware fault then :/
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Aglenoth
Postby PCBONEZ » 2018-4-22 @ 16:32
Check the power voltages.
GRUMPY OLD FART
PCBONEZ
Postby Aglenoth » 2018-4-22 @ 18:03
Everything is correct, i have checked the PSU and even replaced it several times
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Aglenoth
Postby derSammler » 2018-4-22 @ 18:22
Aglenoth wrote:I guess it's hardware fault then :/
Did you even try pressing F5?
derSammler
Postby PCBONEZ » 2018-4-22 @ 18:54
Will it BOOT a floppy with no HDD connected?
The HDD may have a corrupt MBR.
GRUMPY OLD FART
PCBONEZ
Postby Aglenoth » 2018-4-23 @ 04:02
It uses proprietary floppy drive that i dont have , the disk booted on second PC
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Aglenoth
Postby PCBONEZ » 2018-4-23 @ 07:12
Bearing in mind I'm going by a photograph....
That looks like a standard 34-p floppy header.
I suspect the only thing proprietary about the original FDD is the mounting and electrically it's standard.
A standard FDD should work for trouble-shooting, you just won't be able to install it in the case.
GRUMPY OLD FART
PCBONEZ
Who is online
Users browsing this forum: Cga.8086, Google [Bot], Synaps3 and 24 guests
