First post, by jheronimus
Hi, all
Today I got myself an InWin S500 ATX case with an FSP ATX350F PSU (originally came with a Celeron D) and decided to finally give my Asus P/I-XP6NP5 board a test. Here are the full specs:
- Pentium Pro 200 Mhz;
- 64 megs of EDO RAM in 4 sticks;
- Matrox Millenium videocard.
The problem is that it doesn't POST and there is no video output. The PSU fan is working, the CPU gets hot, the disks spin up (disconnected them for now) What I've tried so far:
1) checked all the jumpers. Originally the board was set for 3.5x instead of 3x, meaning that the CPU would be running at 233 instead of 200 Mhz;
2) tried another videocard, though I know this Matrox to be working. Same goes for RAM (used it in my Socket 4 board);
3) tried to change the "3.3v power source jumper setting" from PSU to onboard and back;
4) changed the BIOS coin battery;
5) reseated all the front panel cables;
6) tried another CPU — another PPro@200.
I'm not too experienced with ATX and I'm out of ideas. Then again, I don't have any guarantee that the motherboard is working or that the PSU isn't too modern (here are the specs).
What else should I try?
MR BIOS catalog
Unicore catalog
Reply 2 of 28, by The Serpent Rider
Are you 100% sure that the board don't miss any components, traces, etc?
Reply 3 of 28, by Cyrix200+
In my experience, going back to the beginning is best in these circumstances.
Take everything out of the case, inspect visually.
Check all jumper settings
Try running just the board + some memory + cpu + heatsink&fan + video card, on a cardboard box. You can power on by temporarily connecting the two power switch pins.
Try different a power supply if you have one
Check JP16 (CMOS clear jumper). Clear the settings.
Are there any beeps from the speaker? Do you have a POST card?
1982 to 2001
Reply 4 of 28, by jheronimus
Murugan wrote:
Have you tried it with less than 4 sticks of RAM?
No, will try that.
No and no.
MR BIOS catalog
Unicore catalog
Reply 5 of 28, by Murugan
Try with 2 sticks and try each combination. I have a socket 7 board that if VERY picky. But it could be a wide range of issues.
Reply 6 of 28, by The Serpent Rider
I would also check if any major chips (north/south bridges) on the board gets too hot when powered on.
Reply 7 of 28, by PCBONEZ
Your PSU only has 130W available on 3.3v+5v.
That's usually enough for a Socket 7 but P-Pro were power hogs and it might not be adequate.
I wrote more on that recently
Re: Building a socket 7 pc from scratch
See the PDF in the link.
An era correct 200w PSU would have about 21a on +5v and about 14a on 3.3v. => Around 151w combined.
An era correct 160w would have around 136w on 5v+3.3v.
Your PSU is approximately equivalent to an era 155w and that's an era server board.
And yes, check your chips.
Reply 9 of 28, by amijim
Get a pci bios diagnostic card and give us the 4 digit code and we will tell you exactly what is going on.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 10 of 28, by PCBONEZ
JidaiGeki wrote:
Maybe also try it with FPM RAM instead of EDO.
The manual says EDO is okay but who knows if that's correct.
Asus can be picky about RAM anyway.
Good idea.
Reply 12 of 28, by jheronimus
Nvm1 wrote:
Maybe an easy to answer question: does it have dallas rtc module? If it has one and the battery is empty it might block the mobo from booting...
No, it's a coin battery, and I've tried three different ones, including the one I knew to be working.
Good idea.
Yes, I'll try that.
Your PSU only has 130W available on 3.3v+5v. That's usually enough for a Socket 7 but P-Pro were power hogs and it might not be […]
viewtopic.php?p=666819#p666819
Seems like the most plausible explanation to me at the moment. I'm getting an ATX Socket 7 board soon that I want to pair with a Pentium-166. If that doesn't work, too, then I'll get another PSU. I basically only wanted to play with Soc8 until I got that Soc7 mobo. But considering I want to stick a bunch of hardware in this machine (three sound cards, a Voodoo, and a NIC) guess I'll have to eventually find another PSU anyhow.
MR BIOS catalog
Unicore catalog
Reply 13 of 28, by jheronimus
I got myself the ATX board I wanted from the start — the Intel Advanced/ML (TC430HX) with Pentium 166. Despite the shit ton of hardware I've put into it (Matrox Millenium, Voodoo 1, 3COM NIC, AWE32, GuS PnP Pro, MusicQuest) the PSU seems to be enough. So I guess the board was dead after all. Besides, my Slot 1 build has even less 5v power (20A vs 21A) and that build has Pentium 3, Voodoo 5 and three soundcards (AWE64, Diamond Monster Sound MX300, SoundBlaster Live!) — I don't think that system eats less power than a regular Pentium 166 (or even a Pentium Pro with just one videocard and no additional hardware).
I do plan to get both system new (never used) power supplies just to protect the hardware, but so far I feel like the 5v issue is somewhat overblown unless you go into ~1GHz territory.
MR BIOS catalog
Unicore catalog
Reply 14 of 28, by The Serpent Rider
so far I feel like the 5v issue is somewhat overblown.
Of course it is. I've seen many AT PII class systems working perfectly fine with 200/230w PSUs.
Reply 15 of 28, by PCBONEZ
Same ATX350-PA PSU? - 2 boards don't work with it?
Reply 16 of 28, by jheronimus
No, it's like this:
1) FSP Group ATX350-PA 350W — bare Pentium Pro doesn't work, but Pentium 166 with a bunch of hardware does.
2) InWin PowerMan IW-P300A2-0 — Pentium 3 with bunch of hardware works. I just mentioned it for comparison, because someone said that PPro is too power hungry. Sure it needs more power than a P166, but not a P3@500.
MR BIOS catalog
Unicore catalog
Reply 17 of 28, by PCBONEZ
Overall I like FSP PSUs but I pretty much expect them to need fresh capacitors at some point.
Usually not hard to recap FSP and after that they pretty much last forever.
Since bad caps can affect individual rails the symptoms won't always be the same between systems.
I'm not familiar with InWin PowerMan.
Caps (even so called 'good brands') are a high failure rate part in old equipment. (Including motherboards and add-in cards.)
Any time you are messing with electronics over 15 years old the caps should be suspect by default.
The older the equipment is the more likely some will be bad.
Describe "doesn't work" a bit better.
Are you getting fan-kick, beep codes, stone dead?
Have you done any voltage checks?
Inspect the chips (incl. chipset, MOSFETS, and any other) for cracks, pits or melted areas.
Reply 18 of 28, by jheronimus
PCBONEZ wrote:
Overall I like FSP PSUs but I pretty much expect them to need fresh capacitors at some point. Usually not hard to recap FSP and […]
Well, like I said, I plan to get both my ATX systems new PSUs soon (I don't have any skills to recap a power supply, honestly). Currently, I'm looking at LinkWorld LW6-600W. Cheap, has 20+4 connector, offers 24A over 3v and 40A over 5v.
PCBONEZ wrote:
Describe "doesn't work" a bit better. Are you getting fan-kick, beep codes, stone dead? Have you done any voltage checks? Inspec […]
No beep codes. The fans, LEDs and floppy/HDD/CD drives all work/make noises when connected. The CPU does get hot. Unfortunately, I already replaced the mobo with the 430HX board, so I can't test any further.
MR BIOS catalog
Unicore catalog
Reply 19 of 28, by PCBONEZ
My nature is to fix things.
Having to scrap an otherwise good motherboard over $5 or $10 in caps is just not in me.
