First post, by Superfish
Hi,
This is my first post, of many no doubt. I have looked and looked but I cannot find online the answer to my problem, so I'm hoping you may point me in the right direction.
I recently bought a second hand Thinkpad 600e to relive the glory days, and so far I have managed to install Windows 98SE.
I also picked up a PCMCIA Compact Flash adaptor, and a SanDisk Ultra 16GB CF card with a view to using it as removable storage for programs and games.
When the CF card is first inserted windows 98 prompts to use the Standard IDE/ESDI Hard disk controller. The CF card is recognised in device manager as SanDisk-SDP, but the yellow exclamation mark points to a Code 10 error (Device not present, not working properly or does not have a driver installed).
There is no drive letter assigned to the CF card, but the machine knows its inserted and it can be unmounted using "Unplug or Eject Hardware" in the Task bar.
The card is formatted using windows 10 as FAT32.
If anybody knows what I can do, or where I can obtain a driver I would be very grateful.
