First post, by noshutdown
i am running win95osr1 on amd386dx-40 and 16mb of ram. while i didn't have much expectation on ie5.5, several applications(namely acdsee and k-meleon which i can remember, and a few others) refused to install or run and demanded updated dlls from ie5, so i installed it.
after a lengthy setup, i tried running it and it simply crashed at launch, and the reported file to cause the crash is shlwapi.dll. the same crash also occurs when i tried changing ie property and apply settings.
now, is the problem caused by a corrupted system, ie5.5 being incompatible with this version of win95, or simply would not run on a 386? has anyone tried the same thing with successful experience?
and, can i get any of k-meleon, opera, retrozilla or other decent browser working on 386 and win95?
Reply 1 of 5, by Jo22
Well, I once ran both IE 3.01 and IE 5.0 on Windows 3.11 on a 386DX40.
https://youtu.be/qtmE_q4HyO0
Not sure if that answers your questions, though. 😐
Maybe IE 5.5 requires a 486 instructions set (a 486DLC could work)..
Win 98SE also came with that version and required a 486
(strictly speaking, some people made 98 run on 386, too).
Reply 2 of 5, by DosFreak
Today retrozilla would be your best but but I'd post on the retrozilla forum on MSFN and ask. If it isn't already compiled for i386 then ask and mabye a build will be posted.
Make your games work offline
Reply 3 of 5, by bjwil1991
According to Wikipedia, the required CPU is a DX2-66 CPU.
Sauce: https://en.wikipedia.org/wiki/Internet_Explor … re_requirements
Reply 4 of 5, by noshutdown
Jo22 wrote:
Well, I once ran both IE 3.01 and IE 5.0 on Windows 3.11 on a 386DX40. https://youtu.be/qtmE_q4HyO0 […]
yeah it may be one possibility, that ms dropped support for 386 in ie5.5. but the 16bit version of ie can also be different from the 32bit version, right?
still i wanna see if anyone managed to run win95 version of ie5.0 or 5.5 on 386...
but again, i didn't expect much from ie5 as already said, its some applications that demand updated dlls from ie5.
Reply 5 of 5, by noshutdown
i also saw that in the readme file, but such hard requirements are not always precise.
just think, even the 16bit versions of ie5 listed a 486dx2-66 as requirement, yet it worked on 386s.
