I'm with DosFreak in this case, the post is a bit difficult to understand (it can be misunterstand at some point).
I suppose you meant to say:
user33331 wrote:Hello ( Win98SE + Laptop BIOS support for max.HDD is 128gb.)
-> Hello, I've got a Laptop with Win98SE. It has BIOS support for HDDs up to 128GB in size.
user33331 wrote:
So if I buy a bigger HDD\SSD upgrade to a 3.0gb HDD PATA\IDE which has Win98SE...
-> So if I buy a bigger HDD or SDD as an upgrade for my exiting 3.0GB HDD, which has Win98SE installed on..
user33331 wrote:
The easiest way is to buy a 32gb HDD\SSD ? (or if bigger gb size I must partition it to max.32gb partitions ?)
-> ..would the easist way be to buy a 32GB HDD or SSD ?
-> And if the new HDD or SSD is bigger in size (capacity in GB), must I (re-)partition it to a maximum partition size of 32GB ?
Anyway, this is by no means a correction of your writing. I just wrote it down the way I understood your post.
Hope it is correct that way. 😅
user33331 wrote:Just clone the 3.0gb drive to the ->32gb drive and so on...? (Without any partitioning with bigger drives.)
Some backup programs can clone the content of one drive to another. Acronis True Image, for example, can do that.
These backup programs take care of everything (Volume ID, parition size, etc.).
