First post, by Nemo1985
Hello everybody!
Getting old made me become a fan of the the nineties, so I went to my garage and I found 3 old pc (an asus p5a with a k6 300 mhz) that somewhat works, a intel labelled vx mb (damn I hated VX at the time, it was bad in both simm and sd ram too) with a p166 that works like a charm (64mb edo ram!) and sadly an Aopen ap5t-e with a pentium mmx 166 mhz that I have been unable to make work (it's a TX mb with the old AT standard).
Today I received an Epox mvp3e with another k6 300.
The question is, once the tx mb was my pupil for old game, 64mb sdram, virge Gx, audio card and a nice maxtor with 20gb full of games, sadly today there wasn't a way to make it work, black screen, no sound from the speaker, nothing.
So I took the chance to keep the cables, processor, ram etc. The case is very small, but I wanted to keep the psu, never know, it could be usefull if I will ever find a good HX at MB, sadly I noticed that there are some cables going from the psu to the case, to be precise to the power on button, is there a way to keep the psu without having to keep the case?
Thank you in advance.
Reply 1 of 4, by debs3759
The switch is only attached to the case with screws. Just remove it and keep it attached to the PSU
Reply 2 of 4, by gdjacobs
Even the switch could be replaced if necessary, but you need a latching double pole switch or relay rated for your local line voltage.
Also, P2B is slot 1. You've got a different board with the first K6.
Reply 3 of 4, by Nemo1985
thank you both for your answers, you are right, mine is an asus p5a.
Just an update, I tried to start from scratch, once I have been able to get many short beep when I tried to start the pc. I suppose it was complaining for the lack of video card, maybe I will be able to get it back to life, otherwise ill stick with the original plan.
It may be a bit off topic but... Now the mb gives one long beep an three short beeps, it could be a video card problem but I tried different pci cards and still nothing... I really can't get what's wrong with this mb...
I tried the sd ram on a working computer and... it seems a ram problem, ill do some further test...
Reply 4 of 4, by Nemo1985
So here I am, the ram is definitely dead, now the problem is about the mb... I did some other test with the working pc and the beep errors coming from aopen mb are for not connected VGA card, I tried different vga that are working on the others pc.
Also I received a k6-2 processor but it seems that they used glue to keep the heatsink on it, I have been able to detach it but the processor is dirty, I tried to use the Isopropyl alcohol but without results.
https://imgur.com/a/daBpQ8Y
