First post, by britain4
Got a nice Toshiba Satellite Pro 430CDT I use now and again, I pulled it out having last used it a few weeks ago and it’s not responding to the power button - the green power light comes on, the power light lights up for a fraction of a second when the power button is pressed then they all go off apart from the “mains” light which flashes orange until you unplug it again
Tried the old battery out and hold the power button down trick with no success, also these have an internal power transformer and I can’t see any bulging caps or anything...
It does the same thing when I try to start it on battery power (the battery does still hold a good charge)
Anyone have any suggestions as it’s a nice old thing and I’ve just bought a new keyboard for it? 🙁
- P-MMX 200MHZ, PCChips M598LMR, Voodoo
- P-MMX 233MHz, FIC PA2013, S3 ViRGE + Voodoo
- PII 400MHz, MSI MS6119, ATI Rage Pro Turbo + Voodoo2 SLI
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500
- Toshiba Libretto 110CT, 300MHz, 96MB RAM
