First post, by MichaelWeaser
I am wondering if Restore partition ever existed in the DOS / Windows 3.1x / 9x era of computers? I have known since windows xp and possibly windows 2000 some companies that sold computers, had a restore partition on the computer that you could reinstall the OS without the CD, But I don't know that if it ever existed with DOS/ Win 3.1x/9x computers, since I know that most computers with those OS's came with install disks.
I want to create something like a restore partition for my older computers. I am thinking of doing something like this . but not sure if it's possible to do. Have a beginning partition that is hidden and also would be the "restore" partition that has maybe DOS installed with a image , and with a dos program to reimage the C partition with the drive image, the way the restore partition would be invoked would be maybe with a custom boot loader , that you would press some key before the operating system would load , that would temporarily unhide the recovery partition to reinstall the OS, or also if the C drive isn't bootable or C drive erased and formatted it would evoke it automatically to reinstall the OS from a image on the recovery partition. I don't know how I would get this to work or if possible at all, maybe someone on here could help me with this.
Reply 1 of 17, by derSammler
Yes, some companies had something like that even back then. It's not even hard to do. Create a dual-boot setup, one Live, one Recovery. Install all your stuff. Once done, boot the Recovery system and use a DOS tool like "Partition Image" (freeware) to dump your Live system partition as a file on the Recovery partition. That's it. Now you can boot the Recovery system and restore your Live system partition from the backup dump at any time.
Reply 2 of 17, by MichaelWeaser
I don't think the dos boot loader has the ability to load different versions of DOS from a different partition , So I think I need some sort of a boot manager? Which I am currently attempting to find one that does what I want to do.
Reply 4 of 17, by MichaelWeaser
derSammler wrote:
What will be your main OS? There are many ways to do it. Of course, a boot manager is the easiest solution.
There is possibly going to be 2 OS, ms-dos 6.22 with WFW 3.11 and some version of windows 9x, either windows 95 OSR 2.5 or 98SE, not sure which . I do believe a boot manager would be easier to use as well.
Reply 5 of 17, by debs3759
It's not too hard to do without a separate boot manager. Take a look at http://www.mdgx.com/osr2.htm#2BOOT.
Reply 6 of 17, by MichaelWeaser
thats not going to work, that's only for if you want ms-dos 6.22 and windows 9x on the same partition, I need separate partitions.
Reply 7 of 17, by chinny22
Partition Magic or similar is probably the easiest Norton Ghost was another round that era.
Good thing is Dos/Win9x is pretty simple/dumb. as long as io.sys rules are followed https://en.wikipedia.org/wiki/IO.SYS then everything else doesn't really matter how its copped across/recovered
Reply 8 of 17, by .legaCy
When i worked wih IT when i had a new customer i usually installed the os, all the drivers and supplement software(browsers,codecs,malware protection) and then resized the partition to the minimum size, and then cloned the partition into the same drive and expanded the clone, and made the small partition hidden.
So when they managed to ruin the os installation, i just pasted the hidden partition once again.
Reply 9 of 17, by MichaelWeaser
I'm thinking im going with an older version of norton ghost , I need an older version of Ghost, that needs installed to a separate DOS partition, newer versions after 8.0 or so , installs it in a folder, as a virtual partition in the C: drive , I want a separate partition, so that is why i'm going with an older version of norton ghost. But I still need to figure out which older version of ghost still has the separate partition.
Reply 10 of 17, by tayyare
If automating the process is not the absolute necessity, this is what I do :
First HDD: Make two primary partitions. For your case, a 2GB maximum FAT16 for MS-DOS 6.22+Windows 3.1x and another larger FAT32 partition for Windows 9x. For Windows 98 SE, the upper limit for this is practically 128GB, but there are patches around to make it up to TB levels, if you ever need to. For Windows 95 OSR2.x, suggested max is 32 or 64GB, I don't really remember which.
Second HDD: Again two primary partitions, just because I think it is more practical than an extended partition and logical drive. First a 2GB FAT16 partition for MS-DOS/Windows 9x data exchange, then a second 128GB (or less) partition fo backup storage, installation/setup files, drivers, program and game zip files, etc.
Now choose a multiboot app. for multi booting. I strongly suggest MasterBooter. It is a shareware program, but unregistered version have very few and not-so-important limitations and allow you to boot up to 3 different OSes. It also has all the tools for partitioning and formating. Comes as a bootable floppy and iso image and with an extensive help document, which are also a big plus.
After creating your vanilla DOS and W9x partitions, installing the OSes and making averything else installed and working, just create another boot floppy with an older version of Norton Ghost in it (I suggest 2003 or 2001) and backup your partition images to the larger partiiton in your second HDD.
You can also choose a larger single HDD and utilize the remaning space as a third partition (you can create up to 4 primary partitions on a given disk) to backup your partition images, but backing up partition images on the same physical HDD does not make much sense in my opinion.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 11 of 17, by tayyare
As I said above, you don't need to "install" older versions of Ghost into "partitions". It is a single executable, GHOST.EXE. Copy it into a bootable floppy, and do whatever you want from there. Ghost 8.0 is 1.3MB so does not fit in a bootable floppy. I suggest 2003, or 2001, if you cannot find 2003.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 12 of 17, by MichaelWeaser
that is the way that I want it , I want a separate recovery partition that is DOS , with norton ghost. and than using a boot manager , will be using norton boot magic or another manager. and then have the image on the same partition that dos, norton ghost or whatever other disk cloning software I use.
Reply 13 of 17, by gdjacobs
I always used Ghost 7.5 CE as it was the most capable version that was still viable for floppies.
Reply 14 of 17, by tayyare
I was happy with 2003 and 2001 both, and thinking that they are better, since they are more recent 😊. I'll be to happy learn what makes 7.5 more capable, so I might be using that instead.
PS: I remember OS2 support has been deleted in later versions, but I'm not into OS2 anymore, so it does not concern me much.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 15 of 17, by tayyare
I really think that having the recovery image in the same HDD that I supposed to be recovering in a disaster situation is a bit reckless, but of course, it is your system. 🤣
Mines are always in a separate HDD in the same system + in an external one, too.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 16 of 17, by gdjacobs
At the time, it was EXT3 support.
Reply 17 of 17, by candle_86
I just use Acronis with an external HDD hooked up via USB, works great for everything. Granted for old enough systems I have to pull the IDe drive and mount it on an external IDE cage and clone over but it just works, and because my backup is on a seperate 4TB hard drive with all other system images i don't have to worry about if my HDD dies totally that I've lost the backup
