First post, by quicknick
I was given this motherboard, looks nice and shiny but unfortunately it's missing some components - two larger caps and around 12 SMD caps and resistors. There's also a broken (cracked) diode (D5, between the VRM and the BIOS socket), but I guess that a 1N4148 should work there.
I cannot find high resolution photos of this board, so if someone has it, please provide some close-ups of the highlighted areas.
Also, any ideas on replacing the missing SMD caps, as they usually don't have anything written on them?
Thanks in advance!
576.24 KiB
