First post, by appiah4
I came into possession of a 75MHz FSB Cyrix mII 300GP 75MHz. I'm not comfortable with overclocking the PCI/IDE, so I was wondering if I could just use 66MHz FSB but up the multiplier to 3.5x as on the regular mII chips?
Reply 2 of 7, by appiah4
canthearu wrote:
Cyrix MII processors are FSB and Multiplier unlocked.
Just set whatever parameters you want.
Excellent, many thanks.
Reply 3 of 7, by feipoa
3.5x works, but if you try to use 4x, many socket 7 motherboards won't work with this unless the BIOS is modded to specifically support 4x. Most super socket 7 boards should be fine though.
Reply 4 of 7, by lazibayer
I found your last year's post about getting 4x multiplier on MII. The databooks I could find only list inputs from CLKMUL0 and CLKMUL1. Could you please share your version of the MII databook? Thanks.
Reply 5 of 7, by feipoa
These are just a few of the documents for the MII.
Reply 6 of 7, by feipoa
I find the discussion on trace capacitance, trace reflections, restive dampening, and diode clamping interesting. It is on the first few pages of CyrixMII_-_MII_100MHz_Bus_Design.pdf
