MichaelWeaser wrote:I am having problems with bootmagic 8 to getting it to boot dos from a 2nd primary partition. I have been messing with bootmagic 8 to try to get 2 different DOS versions to boot on different partitions. I have ms-dos 6.22 on the 1st primary partition and than ms-dos 5 on the 2nd primary partition. it is set up in the bootmagic boot menu to boot from either , but when I select the ms-dos 5 partition I get the "Non-System Disk or disk error" message. Also about 2 weeks ago I have gotten it to work perfectly to boot ms-dos 5 from the 2nd partition using bootmagic, The only difference is I used bootmagic 7 and not 8, which should not make a difference. I am just baffled that I can't get it work again.
I don't know if this is the case, but all boot partitions of any MS DOS (up to and including 6.x) should be in the first 8GB of a given HDD, if I remember correctly. The second requirement is, if you boot DOS from a non first primary, then the preceeding primaries should be setup as hidden (if not already unreadable to DOS, like FAT32 or NTFS partitions). Your boot manager should be doing it automatically I guess, if set up accordingly.
Check Master Booter documentation, it is very helpful about that kind of information.
http://www.masterbooter.com/main/news.php?lang=en
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
