First post, by appiah4
- l33t++
I recently acquired a Slot-A 800MHz Athlon processor on a whim, even though I have no Slot-A motherboards (and I likely never will, as they are super, super rare where I live) but having the CPU for $2.50 was something I couldn't pass up on. The issue is, it came without a cooler on it. By that I mean, it has the metal heatspreader that is part of the cartridge casing, but not the actual cooler that goes on top of that.
I am very unfamiliar with the Slot-A cartridge form factor. Is it cooler compatible with Intel SECC or SECC2 packages? Does it require a different kind of cooler? What can I use to cool this?
