First post, by cyclone3d
- l33t++
So I am putting together a system using this I-BUS 386 SBC and a 14-slot ISA backplane.
I think I can use it as-is, but I don't have the manual and would like to know what the different headers are for. The one marked KBD is obviously for the keyboard. There is also one marked HD LED so that is for the IDE controller. The floppy, IDE, and COM2 ports are obvious as well. The ones marked with the various J numbers are the ones I would like to figure out.
The barrel battery is lithium so if it is good I don't have to worry about leakage.
I have already contacted I-BUS and they don't have the manual for this anymore.
Edit: The model number per the archive I-BUS webpage is simply I386
https://web.archive.org/web/19961106073413/ht … om:80/I386.html
