The best 4:3 monitor?
First post, by mzry
Hi guys,
Just wondering what the very best quality 4:3 monitor would be, in terms of contrast, blacks etc.
Thx
Reply 1 of 48, by root42
Can you specify a bit more?
* LCD or CRT
* Inputs: VGA, DVI, HDMI
YouTube and Bonus
Reply 3 of 48, by buckeye
Don't mean to "hijack" the thread but I'm also interested in this. What about models including both DVI & VGA? What range should we be looking for as far as response time? 5ms seems common.
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 4 of 48, by .legaCy
mzry wrote:
Damn 🤣 sorry! noob mistake.
LCD / VGA
Well nice blacks in flat panels i only seem in oled screens and i never seem one 4:3 oled display.
There some high end 20" crt that supports 1600x1200.
But for older LCD i don't think that the black levels would even compare to a nice crt.
Reply 5 of 48, by lvader
The alternative is to find a widescreen LCD with a good 4:3 mode. you would get black bars down the sides but potentially a much better PQ due to newer panels.
When comparing LCD to CRT it’s not so simple to say CRT has better blacks, CRTs have great on/off contrast but poor ANSI contrast compared to LCDs. With bright material and a small portion of black LCD does better, with dark material and a lot of black on the screen CRT is better.
Reply 6 of 48, by The Serpent Rider
That's long running myth.
34.34 KiB
Reply 7 of 48, by Tiido
If you take a photo in ambient light things aren't gonna look all that favorable, reflections and the light itself making phosphors glow (try turning light on and off for a second in a dark room and then look at the screen, you'll see a faint glow for a little bit). It doesn't help when the brightness setting is off or acceleration voltage drifted over time(this one needs the monitor to be opened so it can be readjusted). LCDs with backlight that is partitioned can acthieve decent contrast, but you'll still see big glow around brighter parts due to the partitions not being very small (several square centimeters at minimum).
Reply 9 of 48, by .legaCy
No thats not a myth, it just require basic knowledge of the "inner working" of the monitor.
The back light of the lcd isn't totally blocked by the lcd black making it not as deep as it could be.
Just grab an ips panel that is everywhere and compare it to an amoled and you will see what i'm talking about.
This picture the glare of the crt glass is reflecting the light, probably the lcd monitor have a matte coating on the glass giving this illusion.
Reply 10 of 48, by konc
Although your statement is far from being wrong, this particular picture just doesn't do it justice. It's an either very bad photo, or a wrongly configured CRT monitor.
Reply 11 of 48, by The Serpent Rider
More light - LCD is better; less light - CRT is better. Glass is not the main problem here.
Reply 12 of 48, by cyclone3d
I like the old Dell Ultrasharp 1908FP as far as 4:3 LCDs go.
Has DVI and VGA. Resolution is 1280x1024
I also have an IBM 20" that goes to 1600x1200 but I haven't compared it to the Dell yet.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 13 of 48, by lvader
Yes its a terrible example. With that kind of example CRT should do well as there are lots of dark bits. A better example with be a chequered board of equual size white and black squares, i.e. something that shows ANSI contrast. A typical LCD can achieve 500:1 or better, A CRT is more like 50:1.
Reply 14 of 48, by .legaCy
https://www.testufo.com/
Nice site for benchmarking monitors
Common good 4:3 CRT 100hz refresh rate, better at multiple resolutions(heavier games you can reduce the resolution and enjoy better framerates and it will still look nice)
Common good 4:3 LCD 75hz at it's best, scalling usually looks like shit(or black bars).
Modern gaming monitors usually will fit nice, i will post some pics of some resolutions and games on my BenQ XL2720Z.
Reply 15 of 48, by bakemono
I have a Dell 2007FP which is a 20" 1600x1200 LCD and looks good with VGA. It also has composite/S-Vid inputs which I have never tried and DVI input which results in a dark picture (could be a malfunction, I don't know if they all do this)
My other LCD is a Planar PL2010 which is brighter but has slower response time and looks blurry with VGA signal.
again another retro game on itch: https://90soft90.itch.io/shmup-salad
Reply 16 of 48, by Tiido
It should be noted that 1280x1024 monitors are 5:4 and not 4:3. 1280x960 monitor would be 4:3 but those seem to be rare, like 1600x1200, 1920x1440 and 2048x1536 are. The few I have seen always go for a lot of money...
Reply 17 of 48, by oohms
I'm using a Benq G2400W, which is a 16:10 24 inch LCD monitor, but it has a handy 1:1 aspect ratio scaler built in. It also has very little input lag and no noticeable motion blur.
At 1920x1200, it scales 1600x1200 nicely
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 19 of 48, by dr_st
It's a malfunction (whether of your monitor, cable or video card - I don't know), or maybe you did not have the Brightness/Contrast configured identically. I have a 2007FP and there are no brightness differences between DVI and VGA.
