First post, by root42
- l33t
After my Octek Fox blew a cap and I replaced the caps, some ISA slots on the board are a bit wonky. To figure out what might be the error (wrong/low voltage, noise on the signal lines, ...?) I am wondering if there is something like a test card?
Might be active, or maybe only passive, with points to attach a meter or scope. So not a POST card, but something which tests the bus.
