First post, by britain4
I’ve just added a small fan to the heatsink of my Voodoo3 2000 and got some fantastic results out of it - seems 100% stable at the 183mhz clock speed of the 3500 and I haven’t tried pushing it any further yet. 3Dmark scores are up by around 1/3 which is pretty crazy.
This has got me thinking about the puny heatsinks and fans on my Voodoo5 - it gets very very hot to the touch even at stock speeds. Much more so than the modified V3 even though that has a huge overclock on it. I’m not necessarily after higher clock speeds on the V5 but lower temps would be nice. Anyone got any tips for improving the cooling on one? Any tips for removing the old heatsinks welcome too, I’m nervous to do it!
My idea was to use some heatsinks like this https://rover.ebay.com/rover/0/0/0?mpre=https … %2F113022989575 and reattach the original fans - they should be much larger in surface area being a fair bit taller and about 5mm wider in each direction, and also keep a nice stock-ish look to the card as I’m not a fan of some of the huge heatsinks I’ve seen some people bolt on - any thoughts?
- P-MMX 200MHZ, PCChips M598LMR, Voodoo
- P-MMX 233MHz, FIC PA2013, S3 ViRGE + Voodoo
- PII 400MHz, MSI MS6119, ATI Rage Pro Turbo + Voodoo2 SLI
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500
- Toshiba Libretto 110CT, 300MHz, 96MB RAM
