First post, by Paal
Hi!
I have an multi I/O card PT-604a. I'm having trouble getting the serial mouse to work with it. I have the Microsoft Serial Mouse 2.1a plugged into the serial port of the card, but it cannot recognize or won't find the mouse at all. I'm not sure of the motherboard manufacturer, but there is an AMI BIOS in this 486 computer.
I have attached this link so I have the layout of the card and the jumpers. The card works well with FDD and HDD and the drive active LED as well.
There are no markings near the jumpers to tell me if this is pin 1 and so on, so I'm not sure if I'm closing or opening the correct pins to configure the card.
I switched to this board from another I/O card that wouldn't let me use the serial port, but nothing has changed, so I guess there is some configuration problems here rather than defect card.
Help!
