First post, by infiniteclouds
The game is playable on my 4.77mhz 1000SX but after the opening tune it instantly skips the Information/Select Controls screen right into the gameplay. If I press the BREAK key I can get the options to appear for a second but it will drop right back into the game. I have to press Break and very quickly Spacebar if I want to get keyboard controls, or Break and very quickly press i for information... but even then the info/rules will fill the screen quickly and immediately drop back into the game.
The gameplay speed itself seems fine (it is 4.77mhz after all) so I'm wondering if this is an issue having to do with a Tandy keyboard vs an IBM ?
Reply 1 of 1, by _Rob
I just found that paratrooper will behave like this in dosbox when two joysticks are attached (or a single joystick and joystick_type=auto (or 4axis)).
Did you perhaps have two joysticks attached?
