First post, by EZFlyer
Having a weird issue where when a certain device is under SCSI BIOS control, the ASPIATAP.SYS driver for my Zip does something weird and DOS says it can't find any files after that driver loads and then it asks for a command interpreter location. The device is a Fujitsu 2.3gb MO drive, tried both MBR and Superfloppy formatting. The SCSI card is a 29160N. The boot device is a Syquest EZ135. Tried both DOS 6 and 6.22. The issue happens under no other circumstance even with a different 2nd disk drive under BIOS control, tried a Jaz. When I throw in a boot floppy to provide a command interpreter and try to access the boot volume, I get a general failure, INT24h.
Any ideas? I'm about to give up.
