First post, by Wolfbayne
Hi Vogons. Looking for a motherboard that supports 486 Dx4-120 and 5x86-133 CPUs and has vl-bus. Hope you guys can help.
Reply 2 of 12, by feipoa
The Serpent Rider wrote:
PCCHIPS M912 rev 1.7
Is there a trick to getting write-back L1 cache working on this board?
Reply 3 of 12, by Roman555
There's a good article Give your 486 PC a kick with the AMD 5x86 - 133. I've used it to run the CPU on a mainboard EDOM MV035D. But the BIOS shows wrong CPU speed and I couldn't turn on the WB mode for L1 cache.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 6 of 12, by debs3759
Asus PVI-486SP3. I have revisions 1.22 and 1.8. Haven't built a system yet with the 1.22
Reply 7 of 12, by feipoa
Actually, I was wondering about this particular motherboard - if anyone has been able to get L1 write-back working on it. Starting with rev 1.7, the BIOS has an option for L1 to be enabled in write-back or write-through mode.
Reply 8 of 12, by jheronimus
QDI V4P895GRN/SMT V1.1. RedHill calls this board simply QDI OPTi 895.
After a bunch of trial and error this board that worked best for AMD 5x86 at both 133 and 160. It might be not the fastest one, but it sure is stable.
Though, honestly, another option is to just get a DX4-100 chip with WB cache. The drop in performance is not that significant, but it would be a lot easier to find a board for it.
MR BIOS catalog
Unicore catalog
Reply 9 of 12, by jesolo
How's the VESA Local Bus performance of this motherboard?
Reply 10 of 12, by feipoa
When using the VLB graphics port, the Asus PVI-486SP3 is about 7% slower in Quake compared to its VLB/ISA-only cousin, the Asus VL/I-486SV2GX4. The PVI-486SP3 is only 1% slower in DOOM though.
When using the PCI graphics port, the Asus PVI-486SP3 is about 7% slower in Quake compared to a PCI/ISA-only board of the same chipset (e.g. MSI MS-4141). The PVI-486SP3 is almost 10% slower in DOOM.
So if you're going to use the PVI-486SP3, I recommend using VLB graphics over PCI. For more speed on a socket 3, you'll want to use a PCI/ISA-only or VLB/ISA-only motherboard.
Source: Performance comparison of 486 motherboards with VLB-only, PCI-only, and PCI+VLB
Reply 11 of 12, by The Serpent Rider
Can't test mine due to dead voltage regulator and DX4 overdrive in my possession is WT only.
Reply 12 of 12, by feipoa
I have an Intel DX4 w/write-back capability. When I set the BIOS to L1:write-back, chkcpu still reports the chip is in write-through mode.
