Fixing an old 486?
Reply 21 of 27, by bjwil1991
He cannot boot from a diskette, even the GoTek USB Floppy emulator due to a BIOS issue.
Reply 23 of 27, by bjwil1991
I forgot to mention: the FCC ID is listed in the back end of the machine, or underneath.
Also, what is the BIOS version?
Is it 1.01 Ref ID xx?
Reply 24 of 27, by df00z
The machine is busy now running that website, so I don't really want to mess with it right now. If\when it crashes, I'll check again, but I just bolted the thing back together. There was a number on the back but it didn't specifically mention an FCC ID, it looked more like a vendor serial #.
Interestingly, freedos + ckermit seems to be working better than Win98 dos did on the p233 it replaced. ckermit is shelling out the various midi programs faster, and the transfer rates over RS232 seem solid.
Reply 25 of 27, by bjwil1991
Well, congrats on getting the system up and running.
Reply 26 of 27, by mrau
nice website, happy You got this running again
would You share a little bit of intel here? how do You choose the sound device on the pc? there is a proxy here that would translate requests into remotely typed in commands and the digitize the output?
Reply 27 of 27, by df00z
There is a raspberry pi running kermit with a DigiKey usb->RS232 adapter attached.
The 486 runs CKermit. The Raspberry Pi hits a restful endpoint, grabs the midi file, sends it via kermit to a ram drive on the dos machine, and sends commands over kermit to run dos programs to play the midi file.
I used to use qbasic + curl + a packet driver on the dos machine and it did more of it's own control - but it wasn't as stable as kermit.
It's now on FreeDos, which seems to be _really_ stable. I haven't had to reboot the box at all.
