First post, by Aglenoth
Is this laptop decent for win98se / dos gaming , and how bad is sb emulation ?
Thanks for advice 😀
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 1 of 3, by Kamerat
Looks like it got some kind of dual sound setup and the CS4624 PCI should be Sound Blaster Pro compatible under DOS . FM isn't very good on the CS4624 and you should select Adlib instead of Sound Blaster for music if it sound totally destroyed.
http://www.thinkwiki.org/wiki/Category:T22
YouTube channel
Reply 2 of 3, by stamasd
If you're looking for good DOS sound compatibility in a Thinkpad, look at models such as the 380XD or the 770D; they use the CS4237 chipset which is quite good in DOS.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
