First post, by Moogle!
So OPL2 requires long delays between writes, but is this true for OPL3 devices working in OPL2 mode? I have a motherboard with onboard sound, CMI8330, and Populous and Adtracker II both make hideous noise unless I turn the 8bit I/O Recovery all the way up to '8', whereas The Incredible Machine can work with that setting at '1'. I have noticed this with other sound cards, YMF-262 and otherwise.
Reply 1 of 3, by Tiido
OPL3 still requires delays but they're many times shorter than what OPL2 requires. Clone chips may have their own special requiremens.
Reply 3 of 3, by Tiido
It isn't software based and all hardware is subject to access limitations in some way, just some implementations can hide them such as use of FIFOs.
