First post, by Vipersan
So ..I recapped and cleaned an ASUS CUV4X motherboard last night ..
Tested with a low end PIII (socket 370)
Id like to make this one my main 98se gamer ..so obviously I want it the best it can be ..
I have some ally smd caps on order to recap an ATI Radeon x800 pro (Saphire) ...which hopefully will cure the odd vertical artifacts.
So ..I need to find the latest bios for this motherboard ..which has one ISA slot ..nice!
..and max out the cpu.
Does anyone know for cetain ..what the best cpu would to work in this mobo ?
rgds
VS
Reply 1 of 2, by dionb
Without modification a P3-1000EB is the best it will do, but if you do the pin mods (or use a Powerleal adapter) it can run a P3-1400S Tualatin; although it won't report the CPU correctly at POST it will work fine.
