First post, by debs3759
Will a 16-bit ISA i/o controller with IDE/Floppy/Serial work in an 8-bit slot on an XT motherboard, or do I need to buy an XT-IDE card and separate 8-bit i/o card for RS232? If I need to buy an XT-IDE, does anyone have a link to a site that sells them? I have only found kits for the latest revision.
Reply 1 of 4, by dionb
Some 16b cards work in 8b slots, but it varies per card.
Bigger issue: AT and later IDE controllers don't need their own BIOS because the system BIOS can handle the drives. XT systems can't so an XT IDE controller needs a BIOS. Some 16b ISA I/O controllers have a BIOS socket for this purpose - like a DTK ST-506 controller I was playing around with this evening, and a simple Goldstar IDE controller I very unwisely sold recently.
So it's possible, but by no means a given.
If you have a controller with a socket for an EPROM but no ROM and nowhere to source the original ROM from, you could use an XTIDE ROM image for it.
Reply 2 of 4, by debs3759
Great, thanks
Reply 3 of 4, by stamasd
I'll plug again my thread on vcfed where I dealt with this exact problem, and how I managed to get a 16-bit IO card with floppy and HDD controllers working on a XT-class computer. Initially with the help of a XTIDE card and a ROM card but eventually I moved all the code in the main ROM area.
http://www.vcfed.org/forum/showthread.php?484 … ebay-components
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 4 of 4, by dionb
Wow. Just wow. Bookmarked 😀
