First post, by aries-mu
I split this sub-topic creating a specific thread:
The laptop has USB 2 and USB 3 ports. Guess what? The SD/SDHC/SDXC/whatever cards reader is interfaced... with the USB 2 controller!!!!
See the little daughterboard, it's the one with the USB 2 ports, while the USB 3 port is on the opposite side of the motherboard:
https://www.laptopking.com/boards/samsung-ati … sb-sd-board.jpg
Which means, no matter what modern ultra-fast SD card I'll put in (even hundreds MB/sec cards), they will all be stuck at ~60MB/sec because of the USB2 bottleneck.
QUESTIONS:
1) In your opinion, isn't this another idiotic choice?
2) Is there anything I can do to "re-route" the SD-CARD reader via soldering wires to the USB 3 controller and somehow "cut" those from the USB 2 ? (I know this is crazy).
Thanks SO MUCH guys!!!
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
