First post, by bjwil1991
- l33t
I'm planning on swapping the AMD Sempron 2200+ (1.5GHz) with an Athlon XP 3000+ (AXDA3000KV4E 400MHz FSB at 2.1GHz), but, the CPU the board supports (KM266Pro Chipset) the AXDA3000KV4D processor (333MHz FSB at 2.167GHz). Both CPU revisions have the same voltage core at 1.65V and I have no idea if the board will support it or not. I understand that putting in a 533MHz FSB Pentium 4 processor into a 400MHz FSB motherboard can fry the board and PSU completely due to the core voltage being a few numbers higher or lower. Will the CPU work, or do I need to purchase the exact CPU off of a website to be on the safe side? Thanks for your assistance.
