First post, by Vipersan
...a 21" Apple studio display crt monitor ..
Flat screen I believe ...but am unsure if this is totally PC compatible..
Does anyone have experience of these ..and if so what inputs/signals are available ..
Apparently the issue is that the display controls only work via this software (for Mac OS obviously). Here someone says there might be windows version:
https://arstechnica.com/civis/viewtopic.php?f=19&t=776081
and here's one guy for whom it apparently worked to adjust the display colors/geometry through the windows graphics driver:
https://forums.macrumors.com/threads/apple-st … s-how-to.76138/
If what is said there is true ..
Then once again I can openly curse ..Apple ..
Unless someone knows a way round this problem...
Such a fekkin waste ..
I hate the exclusive nature of Apple products ...but it is such a lovely bit of hardware ...and the price wont break the bank.
Anyone ?
Hmm, it is a pretty cool monitor. I see one in the classifieds here for a hundred euros. I guess it depends on how much you want to shell out for this one!
Worst case you could run the display control software on an Apple device, like an old iBook, and just switch when you need to adjust?
Do love this picture here, which says a lot about the monitor:
Fancy design, but you can find much better PC compatible CRTs. And cheaper.
Hm wonder if it would be controllable from a PC running emulated MacOS (Basilisk II or SheepShaver). I don't remember if the Mac emulators give access to USB ports. Also don't know if the monitor is controllable from MacOS 8 or 9. Worth investigating if you're up to it.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Well since the seller is prepared to deliver it to my home ..and for £50 all in ..
I may well just buy it and work on a solution later.
Sadly CRT monitors are now fairly scarce in the UK ..particularly ones with large screen real estate.
and as has been discussed in another thread ..my eyes aint what they once were ..so big is beautiful particularly for me.
I'll come back to this thread once I actually own it.
rgds
VS
CRT monitors are scarce everywhere now. I have a bunch but actually want to replace them with better ones and can't find a good one for over a year...
Forget what I suggested above, I did a quick search on the emaculation forums (the main support site for MacOS emulators) and it appears that the ones I suggested above don't support USB at all. You would need a real Mac with USB ports running MacOS 8 or newer to control that CRT.
I/O, I/O,
I/O, I/O
Well ..too late I guess cos I already bought it ..
This could be a huge mistake.
Particularly if the only way to adjust it is to own a mac ..which I do not.
Doh!
So ..is adjustment dialog sent over the DVI ..
There must be a way in ..
a mac can do it ?
so why can an emulator not ?
I'm confused.
wrote:Well ..too late I guess cos I already bought it .. This could be a huge mistake. Particularly if the only way to adjust it is to […]
Doh!
a mac can do it ?
I'm confused.
USB was never implemented in the emulator. Why? That's a question for the developer I think. I keep around a Mac G4 for this precise reason (if/when I need to use a piece of software/hardware that isn't supported otherwise). Old pre-Intel G3/G4/G5 Macs are cheap to buy at least here in the US, currently. I got mine for about $30 a couple of years ago, it came as a bare box with no HDD but that was easy to fix. It was useful for flashing firmware on some cards and whatnot.
(edit) the control of the monitor is apparently over a separate USB port, not through the VGA or DVI.
I/O, I/O,
I/O, I/O
I think my nephew has a macbook laptop of some kind ..
I will have to speak to him..
I wonder if he can help ?
Once the monitor is adjusted and set up ..will it retain the settings ..or is this something the mac adjusts each time it powers up ..?
ie if he does manage to set it up ...can I simply connect to a PC once he takes the macbook home ?
That I can't answer. I'm not a Mac guy and never had an Apple CRT.
I/O, I/O,
I/O, I/O
You can probably just control everything via your graphic card's display properties settings.
I just checked US-Ebay and there's iBooks from the 1999/2000 for like 30$...
wrote:You can probably just control everything via your graphic card's display properties settings.
You seem to be forgetting that iBooks don't have VGA ports, only the Powerbooks did (on the subject of old Apple laptops), so I don't really see how an iBook would work with that monitor. 😕
Heh'.... Never liked that halfway transparent color scheme that Apple used back then.
It was populair though. Really populair. I had a salad bowl, a office desk lamp and a cat litter-box in those semi transparent colours. Yup... Semi transparent orange cat litter-box. 🤣
I used to own one of those monitors. Ran it on a pc and never had issues, used the graphics card software for calibration. Worked well for a few years until one day it switches on and died.
Was a nice monitor.
Protagonist: Robot
wrote:
So it's magic! I knew it!
I/O, I/O,
I/O, I/O
100 euros is too much, IMO. While they are indeed high-quality Trinitron monitors with a great picture, the flyback transformers in them like to short and go bad and they are a pain to source replacements for. I have two 17" Studio Display CRTs, and one of them has already died since I got them last year. The picture would flicker and it would make suspiciously loud hissing/snapping sounds, and one day it finally went bad and smoked up my room.
Unrelated, but they are also heavy as sin. My 17-inch models weigh in at 48 pounds (21.7 kg), and the 21-inch models are a hefty 77 pounds (34.9 kg). You can definitely move them around with a bit of grunt work, but as a precaution, know they are a back killer. 😲
