First post, by bestemor
Are these useable for something 'useful' in a normal (retro) computer ?
https://www.ebay.com/itm/MICRO-MEMORY-MM-5425 … 2M/401133279498
Not really sure what their original purpose were, but... 😕
Reply 1 of 6, by weldum
it may be for industrial use or something like that i think, if that's the case, it may need specific drivers. from what i know, these might be used to save specific data to a (kinda) non-volatile memory that's not a harddisk and is writtable (not like rom or eprom that were common)
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 3 of 6, by mrau
you can have a really fast windows swap file ;] or as just pointed out a fast journal - starting from ext3 i believe and some others - so its not for the really old machines; its also unclear what kind of interface this offers;
Reply 4 of 6, by weldum
it's pci-x, so it may be using either a custom bus to connect on the computer, or may be using IDE, SCSI or SATA
Reply 5 of 6, by cyclone3d
These were actually made by the company I work for but not the division I work for.
Checking to see if I can get access to the documentation and/or drivers.
I found a site that has a link to the datasheet:
https://www.artisantg.com/TestMeasurement/737 … CI_NVRAM_Module
And here is a listing for one that is even cheaper:
https://www.ebay.com/itm/Micro-Memory-MM-5425 … 75.c10#viTabs_0
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 6, by bestemor
Ok, so judging by that first link, this looks like to be on par with those olden mpeg decoder cards, from before video cards could do it themselves or whatever... Regarding current usefulness I mean.
.....old NVRAM cards, the Micro Memory MM-5425CN/256. This is a PCI-X card consisting of 256MB ECC DRAM memory backed up by 2 rechargeable batteries of 1950mAh. As the cards are using PCI-X....
History and usage:
This type of card was used back in the days when SSD caching and memory (especially ECC) was quite expensive. They were primarily aimed at fileservers or filesystems that were IO intensive so the journal could be placed on the card and alleviate the IO from the journal to the card.
And didn't notice the PCI-X, which makes it even less useful, IMHO.
Oh well, learning something new each day on this forum, heh... 😀
Thankyou all for the input!
