First post, by Gazirra
I'm working on a retro PC, taking one of Phil's Computer Lab builds and modifying it a bit. The motherboard I have (AOpen AX6BC) has no ISA slots, but has an integrated sound card (AD1881 Codec Chip, according to the manual). What do I need to know about this audio card? Will it work with DOS games?
Reply 1 of 17, by cyclone3d
From what I can find, the AD1881 will NOT work in pure DOS mode.
You can use it for DOS games if launched through Windows 9x though.. although it is not the best to use.
I would recommend a PCI sound card that either has a PC-PCI/SB-Link header (for full ISA type support of DMA) or one that doesn't need EMM386 loaded for DOS support.
Yamaha YMF7x4 based cards are going to be about the best, even ones without a PC-PCI/SB-Link header. The stock configuration utility will work great with your motherboard and be able to use DDMA.
They have authentic Yamaha OPL3 built in and yo get hardware MIDI in Windows.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 17, by collector
Wrong forum. This forum is for DOS games on *modern* systems. Ask old hardware questions in Marvin. Marvin, the Paranoid Android
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 5 of 17, by appiah4
Gazirra wrote:
When I do find a sound card, would it need the -12V rail for ISA slots?
Depends on the card really.
Reply 7 of 17, by stamasd
Depends on your luck and your ebay search skills. I've seen them go for as low as $5 or as high as $30 or more.
A couple of years ago there was a source of cheap Chinese generic PCI sound cards that used a real Yamaha XG chip. I got a few of those for $3 a piece. Unfortunately that source has dried up and I can't find any more of those. The downside is that they didn't have PC/PCI headers or solder pads, and also didn't have joystick/MIDI port. Only basic audio jacks. They looked like this, just with red PCB and Yamaha chip instead of CMI:
https://ecs7.tokopedia.net/img/cache/700/prod … 4c2157a933e.jpg
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 8 of 17, by Nprod
I'm thirding the advice to use a Yamaha YMF7x4 card, the OPL3 sound is genuine (since it's Yamaha), the XG synth is excellent and it's designed specifically to be compatible with older DOS software. You even avoid some of the weird SoundBlaster-specific quirks like the hanging note bug in some games. They're cheap too, you can find them at fleamarkets for next to nothing. They're easy to spot with the big XG logo on the main chip:
Reply 9 of 17, by stamasd
Or like this for a smaller version as YMF744. Still with a big XG logo.
I/O, I/O,
I/O, I/O
Reply 10 of 17, by appiah4
The ESS Solo-1 is a better alternative to a novice I feel.
But then, I love the sound of ESFM..
Reply 11 of 17, by gdjacobs
Please be aware that the XG synth on YMF-PCI cards is not purely a hardware solution, so it won't be available via the DOS drivers.
Reply 13 of 17, by Kamerat
It's a good card for your chipset/motherboard running DOS games as it is the right revision for DDMA support on the 440BX:
YouTube channel
Reply 14 of 17, by Gazirra
Kamerat wrote:
Sweetness! I thought I'd have to pay a ton for my sound card! 😁
