First post, by GabrielKnight123
Hi all, I am replacing an AT power supply fan that was pulling air out so it was not blowing air onto the internals of the power supply but should I replace the fan the same way it was originally or is it best setting it as blowing air onto the components or sucking the air out? the fan is located at the back of the PC so not below the psu inside the case.
