Well ..I guess I can only hope the 1300 Morgan will work in my board ..
I am a bit confused already tbh ..as It currently is running a Duron 950 ..which is out of spec according to the manual ..
Unless I'm misunderstanding something..
This is an extract from the manual.
Support AMD Athlon 700∼1GHz processor
∗ Support AMD Duron 600∼750MHz processor
∗ Support 100MHz F.S.B.
∗ Support 200MHz (Double Data Rate)
∗ Reserves support for future AMD Athlon/Duron processors
I guess the getout is the last line which includes the word 'reserves'
maybe I should look at Athlon cpus instead ?
Thanks for the explanation btw
