First post, by Viper87
Hi, what is the best mainboard for AGP graphic cards testing system? I was thinking about 775i65G R3.0 or AM2NF3-VSTA
Reply 1 of 6, by stamasd
For me a hypothetical "ultimate" AGP board would have a (non-existent) 440BX-enhanced chipset with native support for 133MHz FSB+correct dividers for AGP and PCI clocks, support for universal AGP 2x/4x/8x, support for DDR, PC/PCI connector, PCI and ISA slots. SATA would be nice but that can be shoehorned in with adapters. If such a board existed I would be happy. But it doesn't. 🙁
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 2 of 6, by Viper87
by ultimate i mean the fastest [fastest possible cpu support] for testings graphics like hd4650 hd3850 or older x1950 gt7600, so i need fast 4 or 2 core cpu like phenom II or core 2 duo + OC it
Currently im using Gigabyte K8NS-939 + Athlon 64 3700+ @ 2.7 GHz and its fine for older gpus like matrox p650
Reply 3 of 6, by dionb
For testing *any* AGP card, you want a board with a universal (4x) AGP 2.0 slot that can handle everything from old 3.3V AGP 1.0 cards to the last AGP 3.0 8X things. If you go for a newer AGP 3.0 (8X) board, you can't test AGP 1.0 (2X) cards.
Reply 5 of 6, by SPBHM
apparently the am2nf3 can run the PII 980 (3.7GHz), and it runs DDR2, can the other really compete when it's using DDR1 and is limited to 65nm Core 2 and lower FSBs?
