First post, by okenido
Hello
I have the choice between using PC133 or PC100 sticks for my build. They are both CAS3, and no matter which one I choose, they'll run @100mhz FSB.
I was wondering if choosing the PC133 is better. Will PC133 CL3 sticks act like PC100 CL2 when forced to run at 100mhz ? I can't check since it's an Intel SE440BX-2 motherboard, there are no options to tweak RAM timings.
