Reply 20 of 31, by fitzpatr
- Member
wrote:Thank you for your replies :) […]
Thank you for your replies 😀
The theory that the expansion board may not be recognized is interesting !
As a test I tried Monkey Island 2 which is too modern for this PC even with an accelerator, and the game launched well. Of course the scrolling was slow, but it means that the pc should really have more than the memory avaliable displayed by Commander Keen. I don't know how much memory use Monkey Island 2 but certainly a lot more!
I encountered the same issue with Catacomb Abyss, which is from the same team.@Tayyare : By the way i am interested by your offer to do a 360k image of dos 5.0 in order to try MEM.
Try removing the memory board, and then check what Keen5 reports for Conventional Memory.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
