First post, by bjwil1991
- l33t
I purchased a Double Speed Mitsumi CD-ROM drive at a thrift store that was in an NEC MultiSpeed 8x CD-ROM drive box with the fixings (IDE controller card, manual) and when I installed it into my Packard Bell Pack-Mate 28 Plus, everything went south. The CD Drive won't read CDs, however, in Windows 95C and MS-DOS, it gets detected.
This is what I get when I try to access the CD-ROM (also, the light turns on briefly and the motor clicks for a split second):
MS-DOS
A:\>dir D:
CDR101: Not Ready Reading Drive D:
(A)bort, (R)etry, (F)ail?
Windows 95C
D:\ is not accessible.
The device is not ready.
[Retry] [Cancel]
I also tried it in another system and it does the same exact thing.
Model: CRMC-FX001DE (has a Multimedia PC 2 emblem on the front end).
Connections:
1 Molex
1 IDE 40-pin (keyed)
1 Jumper selection (CS, SL, MA)
1 MPC audio out to sound card
Is it toast, or can it be fixed? It even says "no serviceable parts inside," which that's Mitsumi for you. I have another CD drive and it works, but, too new for a 486, and every IDE cable I have works (other CD drives and HDDs gets detected and work without issues). Cleaning the logic board connections for the laser assembly didn't help at all.
