First post, by C0deHunter
Hi all,
I am running Win98SE on a DELL Dimension XPS 750r with the following specs
ATI Rage 128 Pro 32MB AGP
Sound Blaster 16 CT2910
512MB RAM
Here is the issue:
When I install and attempt to play a DOS game, I simply have no mouse control, even though I have installed the Phil's Computer LAB's MS-DOS Mode Super Easy, I even tried the built-in Win98SE's boot into DOS mode, with no luck.
My mouse is working inside Windows obviously, it is a two-button (with a wheel) Logitech laser mouse.
any idea why?
Thanks
p.s. I just got back into the vintage/retro DOS/WinX gaming world! I just this DELL desktop and a 17" Sony CRT, absolutely love it!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 2 of 11, by C0deHunter
Shagittarius wrote:
I'm not familiar with Phil's tools but my guess would be that you need to load a mouse driver in DOS.
Thanks for the response, yes, I am aware of that, and that is *exactly* what his tool does. I am baffled.
Here is link:
https://www.youtube.com/watch?v=f52bZzWs-u4
Reply 5 of 11, by dr_st
Not sure he knows how to do that. People who know their way around DOS typically do not install Phil's "MS-DOS Mode Super Easy". 😁
In any case - why not just play the DOS game from inside Windows? Most games run just fine this way (on modern PCs, often better than in pure DOS), and you will obviously have a mouse driver.
And yes, if that mouse is USB, it will generally not work under DOS.
Reply 6 of 11, by treeman
if its a ps2 mouse get the drivers and install info here
https://www.bootdisk.com/readme.htm
(about half way down the page)
if its usb prob won't work in dos, I tried a usb mouse with a ps2 converter in dos using cutemouse which is supposed to support that but didn't work.
Ended up getting a ps2 mouse and the standard mouse.com and works easy like that
Reply 7 of 11, by dr_st
It supports it only if the mouse itself supports it. USB and PS/2 are not pin-compatible; to work with a passive adapter, a mouse has to support both modes (some do, many of the newer ones don't).
Reply 8 of 11, by collector
Ask old hardware questions in Marvin. This forum is for old Windows games on modern systems. Marvin, the Paranoid Android
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 10 of 11, by redjr
Hello,
I've gone back in time and I'm trying to get the early version of Win98 up and running on an era appropriate laptop. The issue I'm having is that after Win98 installs and boots into Windows. I cannot get the mouse (PS/2) to respond right. At the slightest touch the mouse pointer start zipping around the screen and opening folders, files and is totally uncontrollably. If I unplug the mouse and plug it back in it may or may not correct the problem. I've tried changing the mouse with no difference. This is behavior I've never seen before hence posting here.
Is there a universal mouse driver for Win98 that will work and correct this problem? Anyone here had a similar experience?
Reply 11 of 11, by BitWrangler
Maybe you need to set DPI lower or turn off acceleration in the DOS driver. However, hot plugging PS/2 hardware is not a good idea, it's not meant for it.
