First post, by furan
- Member
I got a 3DO Blaster running last night.
First, let me dispel the rumor that an exact model of CD-ROM drive is needed. It just needs to be a drive that speaks Panasonic/Creative (remember there are 2 or 3 interfaces, IDE, Panasonic/Creative, and Mitsumi? I think). I have it working with a 4x - maybe that will cause a problem with some game, but I haven't seen one yet.
Second, if you are having trouble getting video, it's important to know how that VESA feature connection works. The connection has two "modes" - in one, you listen to the analog R/G/B signals. In the other, you get 8 bits of color information, with the card running in 8 bits. A lot of later cards skip running the 8 bit data lines to the feature connector especially if they have an internal RAMDAC.
The latter is what the 3DO Blaster requires. They sample the VESA feature connection for their chroma key color and use that + hsync/vsync to know where to inject their analog signal. This is probably because sampling just the analog signal for the colorkey would require supporting a wide range of a particular color (remember, they are windowed). The software hints at supporting a 16bpp screen as well as 8bpp, but I can't figure out how that would work with the VFC in 'digital' sampling mode.
If you are having trouble with video, go with a good old standby, like a Cirrus Logic card. But don't worry so much about having that *exact* CD-ROM drive. The B model works, the 4x model works, etc.
