First post, by Dog
I managed to find a brand new rack mount case at Goodwill that was advertised as being designed for a desktop computer in industrial settings. I thought it would be fun for a first retro build. I found out after buying it that manual only lists support for baby at motherboards. This seemed like a bit of a downer because I was having a lot of trouble finding a motherboard I wanted to work with. While looking at the wikipedia page for baby at though, I noticed that the max width on the specification seemed to just barely fit atx. This made me wonder if the case may also support atx. I tried to start converting atx screw locations with what I could find online, and I think it may be within tolerance. However with this being my first build, I'm not sure if I'm doing something wrong and confusing myself.
Below is the specification for the case:
Any help would be appreciated.
Reply 1 of 5, by dionb
You found a BabyAT case and want to hack it to (u) ATX?
BabyAT cases are much rarer these days than anything ATX (which can essentially be bought new). Please don't mangle it. Instead swap it with another enthousiast for an ATX model.
Reply 2 of 5, by Dog
I wasn't going to modify it at all. The question was looking at the specification I thought it may support both without explicitly stating it. Looking online I also saw the claim that some case makers supported both when atx was becoming the new standard. I was asking for a sanity check if this case may be one of those. 305x244mm seemed to fit. Trying to convert the dimensions to a few specs I could find for screw holes on ATX seemed like it may actually line up. I don't have an ATX board to throw into it. If I really have to I can go and find one I can buy purely to try to screw it in, but I was trying to avoid that.
Reply 3 of 5, by SW-SSG
Some of the screw mount locations between Baby AT and ATX are indeed the same, but all AT cases (supposedly including yours) lack the rectangular I/O back panel cutout that showed up with ATX, and typically aren't tall enough to accommodate the upper 1/3 of an ATX board; hence the sentiment about needing to mangle an AT case to make it work for ATX.
Reply 4 of 5, by The Serpent Rider
If only custom backplates with AT keyboard, LPT, 2 COMs, 2 USBs and PS/2 connector were available.
Reply 5 of 5, by Dog
That makes sense. Height in this instance doesn't seem to be an issue - there is just under 7 inches of clearance to work with. I hadn't thought about the backplate at all. The entire expansion slot area is removable and separate from the case. However I'm guessing its not an easy swap with an atx case, and even then I may be better off using a baby at here and trying to find a rack mount atx case.
Thanks
