First post, by Ganz-HUNGARY
Hi!
I found this mobo somewhere here at home. And for the most part, it works, with a modded RTC. But, it's capable of running a 5x86. And I have no VRM Module. Can I use an ATX PSU, and connect the 3.3V rail directly into the VRM socket? The pinout is like this: The top row is 5V, and the bottom row goes to the cpu. Using jumpers, we can use 5V CPUs.
Reply 1 of 3, by quicknick
That's actually a neat idea, I don't see any reason it wouldn't work. Just make sure the CPU power plane is completely isolated from +5V (so you don't have a short between 5V and 3.3V rails.
