pc rom for Radeon ATI 7000 sapphire?
First post, by chrisNova777
just fired up an old GA-586VX board (rev3.36)
https://www.gigabyte.com/Motherboard/GA-586VX
i need a video card to go with this board
all i have is a radeon 7000 sapphire that is currently flashed for mac..
does anyone know where i can find the pc rom to flash it back to pc?
will this card work for DOS/win3.11? windows 95?
Reply 1 of 20, by chrisNova777
http://web.archive.org/web/20040606121059/htt … driv%20bios.htm ftp://ftp.fic.com.tw/vga_card/bios/ati/a70l/
i think i found it on this ftp site link thanks to the web backup of the above page
but its not letting me flash it!
flashrom -i shows the adapter
but flashrom -l says it is LOCKED!
and i cant figure out how to force the flash
anyone able to help me?
or if anyone knows this card will not work in DOS please tell me ASAP 😀 so i can stop strugling to make this work
need a graphics adapter for my pentium 75Mhz!!!!
if i could get this PCI radeon 7000 64mb card to work i will do a cartwheel
Reply 3 of 20, by chrisNova777
i have a mach64 but it is damaged.
i wish i had the skills to repair it.
its got a broken inductor on the pcb that is breaking one of the signal paths for the blue color.. so verything is R+G but no B (looks yellow on the screen)
like as if u had a bad VGA cable or something
im happy at least my pentium 75 is working
but the FAN in the PSU is not working.. and its the only PSU that i have that will power this AT form factor Pentium board
im going to have to replace it somehow
Reply 4 of 20, by chrisNova777
i have 2 Rage 128 GL cards that originated in Macintosh G3 B+W machines
i sure wish i could find a way to flash one of them for PC use..
does anyone have any rom bios from any of these cards?
http://www.vgamuseum.info/index.php/cpu/item/ … ati-rage-128-gl
Reply 5 of 20, by appiah4
Here is the PCI BIOS for the Sapphire Radeon 7000 32MB. You can flash it in DOS using ATIFLASH, "ATIFLASH -F -P 0 BIOSFILE.ROM" I backed it up myself using that. Alternatively using flashrom you should be able to do "FLASHROM -F -P 0 BIOSFILE.ROM".
Reply 6 of 20, by chrisNova777
i was trying to flash the card last night but it says that the rom is locked
and i dont know how to unlock it! i tried to download ATIFLASH to unlock it as i couldnt find an unlock function with flashrom program
but the atiflash program didnt even see the card! so im stuck using my broken mach64 which outputs yellow graphics because of a broken inductor on the pcb
also my 7000 radeon is the 64mb version (PCI) by Sapphire and its presently flashed to mac bios
i was able to save the current rom i think? to a file of length 32768
someone told me that radeon 7000 wont work for DOS/win95? which is why i started trying to look for ati RAGE or Mach 64 cards or a RIVA128 PCI but i saw that theres a win98 driver for the r7000??? wont that work for win95 osr2.5 aswell?
i put this GA586VX Pentium 75 box together because my abit be6 did not want to power on.. no matter what i did.. but miraculously my ABIT BE6 board started working again last night - i have a coppermine PIII 700Mhz in that board.. with OSR2.5 installed running of a Matrox G400.
trying to put some old 1990s computers together to make use of some old MIDI hardware that i have that connect via SERIAL / PARALLEL & ISA bus 😉
my 1990s machines:
AM386DX40 (unsure of board) + Cardinal 700 VGA ISA
Asus VL/I-486SV2GX4 (486DX2-80Mhz) + Cirrus Logic VLB graphics
GA586VX rev3.36 (pentium 75 - socket 7)
ABIT Be6 (pentium II/ III slot 1) + Matrox G400 AGP
also have a performa 5200CD macintosh with an 80gb hard drive + 10base-T networking
i have an AOpen AX3S-U with a Tualatin 1.4ghz PIII + Matrox G450 AGP
and an Asus P4B533 with a 2.4 Ghz P4 Northwood + Radeon 7500 AGP
and an Asus A7V600 with a Athlon XP 2500 (Barton) + Geforce 6200 AGP
Reply 7 of 20, by Roman555
Is it really? There is web site that has a bunch of graphic card drivers.
You can try this
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 8 of 20, by chrisNova777
anyone know how to unlock the rom?
Reply 9 of 20, by appiah4
It may be locked down in hardware if the -f switch in atitool does not work. As a last resort try UNIFLASH..
Reply 10 of 20, by Roman555
Yes, flash chips have a pin for "write protection". chrisNova777, would you upload photographs of the graphic card and a place around the flash chip?
Reply 11 of 20, by chrisNova777
well i know it is flashable somehow because someone made it into a mac card in the first place.. i got given this card from someone else but i believe they ordered it on ebay.. already flashed to mac bios, so that would make sense.
Reply 12 of 20, by Roman555
Ok. chrisNova777, have you read this techpowerup guide ?
It says there's a key to unlock the flash, but I don't know if it helps in your case.
atiflash -unlockrom X
where X - adapter number
And could you write here a type of the flash chip?
Some people used -sst key to force using sst flashing algorthm, something like
flashrom.exe -f -p 0 <yourbios.bin> -sst
Reply 13 of 20, by chrisNova777
well after downloading a million diff versions of flashrom and atiflash i finally succeeded when i found the version of atiflash that actually had the comman "-unlockrom" and it was so simple. i typed atiflash -unlockrom 0 and it just said "OK" and it worked!
i think maybe also because i used an Asus P5B533 motherboard this time... and the machine wouldnt let the monitor come on if i used an AGP video card i had to use my damaged ATI mach 64 as the primary video while i flashed the r7k 64mb sapphire card.. but! finally! SUCCESS! its working perfectly now inside my pentium 75 and i can finaly see proper colors + graphics..
is there a windows 3.11 driver for the radeon 7000 tho? or should i stick to windows 95?
maybe i need to get a pentium 166 or 200 cpu now aswell
this is GREAT!
Reply 14 of 20, by appiah4
chrisNova777 wrote:
well after downloading a million diff versions of flashrom and atiflash i finally succeeded when i found the version of atiflash […]
this is GREAT!
Please zip, attach and share the version of atiflash that worked here for future reference so people in the future may find what version you are talking about.
Reply 15 of 20, by matze79
https://www.techpowerup.com/vgabios/
look here.
Reply 16 of 20, by chrisNova777
i agree that would have made the most sense if i had of been that organized to pull that off;
ill try to attach it if i can locate it again, its on one of my floppies in here somewhere
Reply 17 of 20, by chrisNova777
thanks to all; i did manage to get the radeon 7000 flashed + working on pc;
ive just been playing police quest for the first time since the 1980s with it 😀 🤣
Reply 18 of 20, by WedgeStratos
Sorry to necro (this is gonna be a great introduction post). I'm glad you got your Radeon 7000 flashed and working again, Chris. However, I'm stuck in the same boat, and there's been no contributions to fix this problem for anyone else.
I also have a Sapphire Radeon 7000 64MB model that was flashed to Mac Bios. Attempting to use the available BIOS file from appiah4 results in some obvious garbled image, since his is a 32MB model. Does anyone have a backup of the 64MB model available? I've not been able to find it, the FTP site listed above is gone, and the archived site does not have the files stored for the 7000.
