First post, by Geon106
Hey all,
So I've gone and purchased an AWE32 CT2760 soundcard. I've downloaded a driver CD and it's set up my autoexec.bat file. I can play MIDI in Windows absolutely fine.
I then tried a game(DOTT) and got MIDI music but no voices.
I tried Hexen and again, got MIDI but no Sound FX. I ran Diagnose.exe and ran through the steps, it found the card fine with these settings:
Address 220
MIDI port 300
IRQ 5
Low DMA 3
High DMA 7
At the end all tests worked, 8-bit, 16-bit and both music tests. All sound fantastic.
I tried other games but again, only music no FX or voices
I've tried checking the mixer in the Soundblaster folder and moving all the sliders to the right
I have disabled my serial ports and printer port to make sure there are no conflicts.
I've tried in games different options, SB, SB16, AWE32
I've tried adjusting the jumpers on the board, I noticed no jumper on MSEC, added one but it's remained at 300 rather than 330 though this is unlikely to cause the problem. I've also added a jumper on the pins for MIDI emulation as it should have a jumper by default but this made no difference.
I tried setting my configurations in the BIOS to "auto" rather than manual reserving IRQ5 for legacy ISA but all that did was made the card IRQ2 (instead of IRQ5) with the same symptoms.
Windows sounds play fine, MIDI music plays fine. I'm just at a lose with Voices/Sound FX and right now feel like I've wasted nearly £100 on this card when I had less issues with my ALS120 SB Clone.
My autoexec.bat:
Mode con coverage prepare=((850) C:\Windows\Command\eta.cpi
Mode con coverage select=850
Keyb UK,,C:\Windows\Command\Keyboard.sys
LH C:\Windows\Mouse.com
SET MIDI=SYNTH:1 MAP:E MODE:0
SET SOUND=C\SB16\CTSND
SET BLASTER=A220 I2 D3 H7 P300 E620 T6
C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL /S
(please note it's "I2" since the IRQ changed, it was correctly set to "I5" before.) Ive tried Googling the issue but seem to find people having the opposite issue, Sound FX/Voices but no MIDI, plus a lot of mention of the PnP cards but not the non-PnP variants)
Thank you everyone in advance!
1993:A500
1997:Apricot MS540|P/166|16M|Rage3D 2M
2000:PB 9533|P3/533|128M|Voodoo3 2000 16M
'04:P4/3G|1GB|NVIDIA 5700 256M
'07:AMDX2/3.2Ghz|4GB|8800 GTX
'11:i5 2500k|16G|AMD 7950
'16:i5 6600k|16G|NVIDIA 1080|SB AE-5
'21:5900X|32GB|6800XT|SB AE-5
