First post, by The Serpent Rider
Since I have both, might as well do some documentation.
992.48 KiB
1.22 MiB
1.3 MiB
Compared to the previous revision, 3.2 has the following improvements:
- Additional NEC K3296 voltage regulator (2 vs 1)
- Better VRM coils
- Additional ultra low CPU voltage options (1.3-1.9v)
- Colored IDE connectors
- South bridge M1543C revision B1 (A1 on 2.2)
- Stepping D north bridge M1542 with integrated TAG RAM (optional, 512mb RAM cached)*
- Revision C1 M5819P IC chip (B1 on 2.2)
- More streamlined jumper configuration
- Different capacitor manufacturer: Hermei (3.2) vs Choyo + GSC (2.2)**
*Looks like revision 2.2 comes only with external cache, so only 128mb RAM can be cached on those.
**Looks like most early 3.2 boards with external TAG (stepping E NB) are still Choyo + GSC combo.
Reply 1 of 9, by The Serpent Rider
Did some further investigation and found photos of revision 1.1:
890.47 KiB
954.01 KiB
Apart from the different PS/2 connector placement and 2-pin CPU fan, it's practically identical to the revision 2.2. Although maybe it doesn't support AMD K6Plus.
Reply 2 of 9, by Sphere478
Darn, I have the 2.2 version.
Have you had any issues with getting the thing to act right on the 100mhz fsb setting? I couldn’t get cd booting to work until I set fsb lower I have it at 66mhz now. But now am having floppy issues
Sphere's PCB projects.
Reply 3 of 9, by kinetix
Hello my friend. Could you post a photo of the bottom of the rev2.2? if possible in detail the surroundings of the TC40 capacitor.
also, I have downloaded the motherboard manual. More specifically, two manuals, revision 2.2 and 3.2. Being the rev2.2 , this is the one I take as a guide. To test the board, instead of using the K6-2, as a "safety" measure I´m using a Pentium-166. BUT, the jumper/switch configuration in the manual and what is stamped on the board differ slightly!!
Which one do I believe?
also, In the stencil 0 (zero) is ON and X is OFF, as in the manual?
Reply 4 of 9, by dormcat
Just spot one 2.2 at e-waste; will be back and add more details shortly.
EDIT: Huh, I can't remove this post after posting an updated reply. My bad.
Reply 5 of 9, by dormcat
kinetix wrote on 2023-09-24, 02:18:
Here you go:
1.08 MiB
987.77 KiB
I had high hope of this SS7 MB, only to find at least three bulging capacitors. Unlike most bulges that crack the top with pre-carved indentations (cross, three-pronged star, or letter "K"), bulging capacitors on this MB go "downward."
1.31 MiB
The TC40 was the worst one, followed by TC45 and TC44.
Should have grabbed that Epox EP-51MVP3E-M two years ago (sigh).
I noticed that too. The manual gave Pentium 133-200 (w/o MMX) 3.5V but the official Vcore should be 3.3V. OTOH the manual gave Pentium-MMX the correct Vcore of 2.8V.
Yes, those were based on East Asian mindsets. 😅 Gigabyte is a Taiwanese company after all.
https://en.wikipedia.org/wiki/O_mark
https://en.wikipedia.org/wiki/X_mark
Reply 6 of 9, by kinetix
thank you so much. I already solved the problem a couple of weeks ago, the board is alive and well, even better, with the last stable BIOS. you can see here
Help with a Gigabyte GA-5AA rev 2.2
I also send some better images to theretroweb site
https://theretroweb.com/motherboards/s/gigaby … -ga-5aa-rev-2.2
and yes, I replaced the five capacitor on the socket side, and a couple more
Reply 7 of 9, by dormcat
Glad to hear that. 😸
I really felt sorry for that MB I saw, as I don't have tools or expertise to recap it. 😿 I'll ask around if someone nearby has the skill.
Reply 8 of 9, by kinetix
just want to know, be really really sure. how are the holes of C40 on the top side. can you get an even closer image , like the third image but closer, looking that pace below the capacitor.
because i was never 100% sure if one was connected to the upper big vein
Reply 9 of 9, by dormcat
kinetix wrote on 2023-11-04, 01:29:
I've already asked a skillful friend to replace those bulging caps.
