First post, by C0deHunter
- Member
Hello all,
I just received my IDE to CF adapters in the mail, to replace my current two mechanical Hdds (WD 80GB)
* For some odd reason, when I use both of these adapters on the *SAME* IDE Channel (One set as Master, the other one as Slave), the Slave drive can not be detected on my Abit-BH6.
* When I connect the second CF Adapter to the secondary IDE channel (where my CD-ROM is installed) it works (either as Master, or as Slave)
* I am thinking about setting the first CF adapter on primary IDE Channel and set it as Master (obviously), and connecting my CD-ROM as Slave on this very same IDE channel. (for OS: Win98SE)
And
* connecting the secondary CF adapter on the secondary IDE channel as Master (and nothing connecting to it) this is for GAMES (Win98 installed games)
Question:
Do you recommend this? I mean connecting an Hdd (CF in my case) on the same channel with a CD-ROM would not degrade performance?
There are some discussions here, but I thought I consult with you guys first!
httphttps://www.vogons.org/posting.php?mode=post&f=46\
and
https://arstechnica.com/civis/viewtopic.php?f=8&t=784762
Thanks!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
