First post, by athlon-power
I recently got a new motherboard (an Intel SE440BX-2), and so far everything has worked, though I've not yet tested the CD drive functionality. For some reason, every time the motherboard tries to access the HDD, the system hangs and the HDD indicator lights up solidly. If this is when the HDD is the only thing that it can see to boot off of, the system will POST, but it will invariably be unable to actually access the hard drive, just sitting there with a blinking cursor. The HDD itself shows up in the BIOS setup, and worked perfectly fine with the previous motherboard.
If I boot it with a floppy in the A: drive, it will boot into the floppy right up until it has to access the hard drive, in which case, it will do the same thing as it does when the floppy drive is empty, stopping everything entirely to try and access the HDD, which never can be accessed. The HDD indicator also light up solidly while it does this, though I can hear zero activity from the drive when I put my ear next to it. I'm not sure why the mobo is deciding to throw a hissy fit with the drive, and I even went into the bios and gave the HDD delay setting 6 seconds to give the HDD time to initialize, which is the setting that I had on the other motherboard when it worked fine. Not sure what I'm doing wrong here- the drive is even jumpered in the back to limit it to 32GB so that older motherboards can handle it.
Where am I?
Reply 2 of 6, by athlon-power
I tried two different IDE cables with it to no avail, I also tried the other IDE port. The problem with changing it out is that it is an absolute pain to try and change HDDs out of that caddy because it's not got the right sort of railing for standard 3.5" drives, for some reason it's gauged to take something that has the width of a 3.5" HDD, but it seems to be made for something taller than normal 3.5" HDDs.
I have quite a few IDE HDDs I could try, it's just *eh.* Taking hard drives in and out of that caddy is a whole process that I'd like to avoid.
As far as the brand goes, it's a Hitachi Deskstar 80GB from November of 2003. Like I said, I limited it to 32GB through jumpers on the back to prevent any compatibility issues with any old mobos I wanted to use it with.
Where am I?
Reply 3 of 6, by ODwilly
It might be an issue with the onboard IDE. Try a Promise ide pci controller card or something similar. That would also allow you to use the full 80gb of the drive, which would be nice.
Reply 4 of 6, by athlon-power
I do have an external IDE controller, though it's a newer one and it's also had issues with conflicting with the onboard IDE and stuff before on the old motherboard.
I don't want to use it unless I absolutely have to as a result. It's too new to really properly work well with the kinds of motherboards and systems I'm using it for, and I have zero money to afford a new legitimate Promist ATA/133 controller or something similar, but if I'm going to go through all that trouble, I'd probably just get a SCSI controller and an old SCSI HDD.
I've never had any problems using original storage amounts, and to be fair, I prefer using older storage (like old 14GB HDDs and the such), because it's more true to the machine and all that. And if the drive fails, it usually won't take the whole PC with it, so I can just get a new one.
I don't use the old power supplies though. I don't tend to trust those things as much, and if they fail, they can take the whole PC (and might I add, a very valuable vintage PC) with it.
Where am I?
Reply 5 of 6, by athlon-power
So I've got a WD400 Caviar in there right now, and it seems to be working alright. Maybe it was because the 80GB was on Master instead of Cable Select or something, I don't know. I don't see a reason to change the drives anytime soon though, unless the WD400 dies on me. Thanks for the help, though!
Where am I?
Reply 6 of 6, by ODwilly
Good to hear!
