First post, by jaZz_KCS
- Oldbie
Hello fellow Vogoners!
This this is a shoutout / call for help to all owners/former owners of the Yamaha DS2416 DSP Factory and general data horders 😀
I have been looking for quite some time for the factory CDROM (Introduction CDROM I believe it is called) for the DS2416 DSP Factory. Amogst some demos and and old, outdated drivers there is a very small program on the disc that is called "Patch.exe".
It is used to initialize the card and route inputs to outputs of your choice, as the standard settings cannot be changed under Windows itself. I know that there are other solutions/possibilities to achieve this by using one of the DAWs that support the DSP Factory, like for example Logic, Cubase, et cetera. You can even use the small program called LUI for the same purpose and it suits the same needs and is even way more sophisticated than the small tool from Yamaha.
Even though, it would be handy for me to acquire the aforementioned little program, and to complete the driver collection of the hardware that I own.
Please, if any of you has the DS2416 in his/her possession and does have the driver CD that came with it, please consider uploading it into the VogonsDriver database. I have searched for weeks, high and low for the original driver CD, alas to no avail.
Thank you for reading.
KCS
