First post, by Themanwho
Hi all 😎
here is the issue :
when the computer is turned on and windows 98 is loaded, at each time i need to proceed to a re-boot or reset, my computer doesnt restart and i obtain a black screen.
I am forced to turn it off then turn it on manually to see windows loading 😕
Do you know the reason ?
Thank you.
Reply 3 of 9, by Themanwho
Lylat1an wrote on 2020-03-27, 19:08:
Could it be that ACPI isn't enabled/supported on your motherboard?
Hi Lylat1an, ACPI is supported apparently
https://hothardware.com/reviews/soyo-sy6be
I'am going to see in the bios.
Reply 5 of 9, by aha2940
So, the computer powers on fine from cold boot, but when you reboot it just stays there, with a black screen. Now, are you sure the PC is not powering on? couldn't it be that the OS is hanging powering off and that's the black screen you keep seeing?
Reply 6 of 9, by Horun
Win98 reboot issue, have you googled it ?
Look here: https://www.techrepublic.com/forums/discussio … rt-on-shutdown/
or https://www.techspot.com/community/topics/win … k-screen.26181/
Too much beer tonight, will check later....
Reply 7 of 9, by _UV_
Probably caused either by NIC or too modern HDD. In case with hdd such a problem start to happen with UDMA66 and newer drives, because mobo can't enable exact UDMA33 it expects, but UDMA. You may check this by switching HDD to PIO4 in bios. With some HDDs you can force drive to work at certain speed in manufacturer utility.
Reply 8 of 9, by Themanwho
hello thx for the help men.
i tried many things without success :
old 3.2g , 4.5 hdd or compact flash i have the same issue when rebooting.
when i just install ms dos 6.22 and i do a reboot with crlt + alt + sup : same issue too : no boot. I have to power off and power on
Same with windows 98 se 😒
a component should be die.
